Enpass vaults on HiDrive
Setting up an Enpass vault on HiDrive using WebDAV
Enpass vaults can be stored and sync on your HiDrive account using WebDAV.
To set up an Enpass vault for syncing with HiDrive:
    • (Or on mobile devices, tap ICON-UI-add-plus.svg at the top-right corner)
  2. Select WebDAV from the list of syncing options.
  3. Enter your HiDrive WebDAV URL using the following format:
    • https://webdav.hidrive.strato.com/users/{user_name}
  4. Enter your HiDrive login credentials.
  5. Click Connect.
