Setting up an Enpass vault on Yandex Disk using WebDAV
Enpass vaults can be set up and synced via your Yandex storage using WebDAV.
To set up an Enpass vault for syncing with Yandex:
Go to Settings > Vaults, and click Add new vault.
(Or on mobile devices, tap
at the top-right corner)
Select WebDAV from the list of syncing options.
Enter your Yandex WebDAV URL:
https://webdav.yandex.com
Enter your Yandex Disk login credentials.
Click Connect.
