Setting up an Enpass vault on woelkli using WebDAV
Enpass vaults can be set up and synced via your woelkli storage using WebDAV.
To set up an Enpass vault for syncing with woelkli:
Go to Settings > Vaults, and click Add new vault.
(Or on mobile devices, tap
at the top-right corner)
Select WebDAV from the list of syncing options.
Enter your woelkli WebDAV URL, found in your woelkli console settings:
or use https://cloud.woelkli.com/remote.php/webdav
Enter your woelkli login credentials.
Click Connect.
