Setting up an Enpass vault on pCloud using WebDAV
Enpass vaults can be set up and synced via your pCloud storage using WebDAV.
To set up an Enpass vault for syncing with pCloud:
Go to Settings > Vaults, and click Add new vault.
(Or on mobile devices, tap
at the top-right corner)
Select WebDAV from the list of syncing options.
Enter your pCloud WebDAV URL
pCloud (US): https://webdav.pcloud.com
pCloud (EU): https://ewebdav.pcloud.com
Enter your pCloud login credentials.
Click Connect.
